Wire diagram for amp/speakers?
Old Jul 29, 2012 | 08:19 PM
phatisfy's Avatar
S-class
Does anyone here have the wiring diagram for the amp/speaker's? My left/rear door speaker is not working,and I would like to diagnose the problem if possible. Any idea why there's no sound...or is there a fuse for that specific speaker?
Old Aug 9, 2012 | 04:50 AM
745Japan's Avatar
745i BMW '05, S550 '08
Try this. Time to go aftermarket speakers/subs and amp. If you do decide to go that route, let me know. You will need AudioControl LCi6. It sounds awesome btw.
File Type: pdf
Old Aug 9, 2012 | 09:07 AM
phatisfy's Avatar
S-class
Thanks for the info. I tried looking at that diagram. But just can't figure it out. I'm basically looking for the rear left door speaker/tweeter wires that goes into the rear amp? Can you pin point me what those wire colors are. And which connectors are those? Thanks!
Old Aug 9, 2012 | 09:24 AM
745Japan's Avatar
See section 1e of the schematic. Speaker wire will be brown/green On negative side and Solid green on positive side. Tweeter will be section 3l, wire color green on positive side and Brwn /green on negative side.
Old Aug 9, 2012 | 09:33 AM
phatisfy's Avatar
S-class
Where can I find the connector to where them wires go into the amp?
Old Aug 9, 2012 | 09:44 AM
745Japan's Avatar
Amp should be on left inside the trunk. Another way to check your speakers is to adjust fade/balance to that speaker listen for anything abnormal. If you hear a scratchy sound your speaker is more likely shot.
Old Aug 9, 2012 | 09:55 AM
phatisfy's Avatar
S-class
I know where the amp is. It's the connector that I'm looking for? The previous owner had an aftermarket amp/speaker system installed. And I guess when they put it back to stock.the wires got mixed up. I did the adjustment to that specific door speaker.but hear nothing. I thought the speaker might been bad.but it was working when I tried to switch it to the other side?
