Anyway to Default to Audio in instrument panel?
Old Aug 2, 2012 | 03:54 AM
enoyskt's Avatar
sl5
Hello all, Is there anyway to default the shortcut of Audio in the instrument panel on startup instead of trip? Im talking about the speedometers "AUDIO" that shows the radio stations in the middle of the speedo needle. Mine defaults to "TRIP" right now. Thanks all!
Old Aug 2, 2012 | 12:18 PM
Diesel Benz's Avatar
I have not tried this but it should be possible to version code the cluster to remember the menu that was used when engine is switched off. This should not be specific to any menu and should work with the Audio menu too.
Attached Thumbnails Anyway to Default to Audio in instrument panel?-w221-menu-last-mode-memory.jpg
Old Aug 2, 2012 | 05:01 PM
enoyskt's Avatar
sl5
Thanks for the reply Diesel Benz,
Is this through the STAR DIAGNOSIS SYSTEM only? Please let me know and I will tell my indie to give it a shot. Thanks
Old Aug 3, 2012 | 10:46 AM
Star Diagnosis or a compatible generic diagnosis tool (Bosch, Launch etc. perhaps).
Old Aug 3, 2012 | 11:37 AM
enoyskt's Avatar
sl5
Diesel I went through the whole star system and can't find that Page that looks similar to yours under instrument cluster, can you tell me which category menus you went through?
Old Aug 3, 2012 | 12:52 PM
Diagnosis to plant specifications, control unit adaptations, control unit adaptations (variant coding), variantencodierung.
Old Aug 4, 2012 | 06:15 PM
enoyskt's Avatar
sl5
Hello Diesel Benz,
I went through my system and got to the page you are talking about but it does not have the menu option you speak of "last menu..." ect.. Is this specific to region or anything? I see all the others like presafe, navi ect..
Old Aug 5, 2012 | 03:16 AM
Hello Diesel Benz,
Which Star Diagnosis SW release are you using? Which MY cluster do you have in your car? Can you try these in simulation mode with your SDS for different instrument cluster versions. I could also try it with a fresh DAS, the one where the screen capture comes is an old one.
Old Aug 22, 2012 | 09:59 AM
s550148's Avatar
2007 s550
Hey any luck with figuring this out?
Looking to set the default to have the Range indicator come up on startup.
Thank you
