Wheel Brightener - Safe?
Please help!
Please help!
1. If your wheels has been damaged in any way (such as curbing), the use of acidic wheel cleaners (like this) may over time peel the paint away.
2. Since this is acid, it is recommended that you, at the minimum, wear gloves for protection. If it gets on your skin, get it off with water.
3. The smell, if it is hot outside, can cause people to feel sick for a minute. The worse that happened to me is that I coughed due to the scent.
4. DO NOT LET IT DRY ON THE WHEELS. Acid if left to dry can stain the finish.
What I suggest is spending the extra money on Sonax or P21S Gel Wheel cleaner. (I've also heard that Brown Royal wheel cleaner is really good, especially at its cheaper price, but have no idea where to get it) Not only are they much safer and appealing, but they can be left on for an hour then rinse off at your liking. Most say that their performance is equal or better than Wheel Brightener.
BTW if you think your brake dust on your Mercedes is bad, try the same year 750Li. You will start to see brake dust after 3 miles.
Sonax just isn't getting all the dirt out!
http://tinyurl.com/c85klrc
"SONAX Wheel Cleaner's acid-free, non-corrosive formula is safe on all types of painted, alloy, anodized, clear coated, chrome, aluminum and stainless steel wheels. Clean with confidence!"
