HELP sirius satellite radio not recog
2014 GL 450
Just picked up my 2007 S550 and the Sirius satellite radio is not being recognized/ Anything that I can to to either reset (which is what I did already to default system) and have it kick in?
2014 GL 450
2014 GL 450
the thing is I need the # to give to Customer Serv @ Sirius in order to activate and the option is not coming up on the Command . The car is equip with satellite so Im not sure if disconnecting the module and reconnecting with "jump" start it up or is the whole module bad. I have no warranty on the car so at this point its a DIY.
Received 4,435 Likes
'71 Pinto
To retrieve ESN # scroll to Audio, select - rotate to Sat Radio, select - rotate down to Service, select.
Satellite radio module is located behind left trunk panel.
2014 GL 450
