Issue with only the right side of both drive dymanic multi contour seats
I have a 2007 S550 and just recently I have some problems with a part of the multi contour drive dynamic seats in the front.
The part that is not working properly is the right side of the drive dynamic seats. They inflate on cornering but they don’t hold the air. The left sides of both seats still work fine. Since it happens on both sides it’s not a puncture or anything like that. If anybody has had a similar issue, knows of a related TSB, or has some insight on what parts are at play when it comes to the valve that is involved it would be helpful for my mechanic.
Thanks ahead of time.
Let me know what you find out here, I have the same year same car and mine does the same thing
They inflate properly but don't lock in the air properly. Given that it happens on both front seats in the same fashion do you think that the issue would be somewhere outside of the module carriers in the seats themselves?
Also if I try to inflate the seatback sides through the seat adjustment menu both sides inflate properly on both seats but then the right sides go flat. So the issue is a general one with whatever valve(s) controls the seatback right sides.
As long as the pump in the trunk area is solid, the only other culprit is the "carrier". In the pdf, it's #16, for anything in the seat back and #15, for anything in the seat.
I so far have replaced the passenger seat back carrier (commonly called an "adapter"), the drivers seat back carrier/adapter and now need to replace the drivers seat cushion adapter (#15). The diagnostic printout says, "Code # 001=9211. The module carrier for the seat cushion is defective." "Code #002=9307. Control module DSP is not activated."
I am long out of warranty. Indi did work; I bought parts. My digging you can get the adapter/carrier from an authorized MB online part seller for around $300. List is around $440.
That's been my experience in this wonderfully satisfying, but incredibly frustrating option. If the pro's, like Diesel Benz or Konigstiger (thanks for the PDF), see an error in my statement, pls. correct. Thanks.
Good luck.
