Car goes into limp mode - error codes
Old Aug 29, 2012 | 03:24 PM
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
Question Car goes into limp mode - error codes
Today when I started my car the yellow engine light came up and the car goes into what I think is limp mode. No turbo is present (I think) and the transmission wont kickdown at all.
I've red out the following error codes: P2668 who I managed to erase and P3002 who wont go away. Anyone here who knows what the codes means? The car is a S320 CDI.
Old Aug 29, 2012 | 10:16 PM
nimski62's Avatar
From my research it seems like something is going wonky with the accelerator pedal position sensor. This will cause limp mode. You will need star diag to further diagnose.
Old Aug 30, 2012 | 07:15 PM
Tobby's Avatar
It was a sensor in connection with the particle filter who was the problem according to Star. Havn't got the part yet, so I have to wait and see if the problem goes away.
Old Sep 4, 2012 | 02:06 AM
PelicanParts.com's Avatar
SPONSOR
Answer
P3002 - Fuel Air Metering Auxiliary Emission Controls.
roy@pelicanparts.com
Old Sep 4, 2012 | 03:45 AM
Diesel Benz's Avatar
3002 is for the DPF differential pressure sensor (when you read codes with Star).
It could be the actual sensor or just the tubes, check those. A relatively common issue with V6 CDIs/DPF cars.
Old Sep 4, 2012 | 01:51 PM
Tobby's Avatar
I was the pressure sensor. Changed part number 006 153 95 28, car is like new again
