Camshaft Solenoid Recall for W221
Old Sep 26, 2012 | 09:52 PM
amcguru's Avatar
'10 E350, '03 Excursion 7.3 PSD
No need to fret folks...the campaign (not recall) will cover every m272 & m273 engine built. Each engine requires 4 wiring pig tails and there's no way the dealer, parts distribution network & supplier can handle that many vehicle's at once. The solution is to release the campain to a group of vin #'s at a time over a few months.
Old Sep 27, 2012 | 07:23 PM
kblair3d's Avatar
2014 GL 450
Originally Posted by jett3jett
called MB today and gave them my vin , they said there is no open recall on the s550?
Anything?
There is I am bringing my out of warranty '07 tomorrow morning and its covered as per MB-USA
Old Sep 27, 2012 | 07:25 PM
kblair3d's Avatar
2014 GL 450
Xceltnt answer
Old Sep 27, 2012 | 07:36 PM
jett3jett's Avatar
2021 G63, 2016 S550, 2019 RR 👻
The reason my tech was saying no avail recall for my vin is because the previous owner already had the solenoids replaced prior to me buying the car
Old Sep 27, 2012 | 08:49 PM
carboxy's Avatar
07' 911 Turbo, 09 ML63
the vmi says my car is not called yet.. i have to wait..
Old Sep 27, 2012 | 09:49 PM
mb1000's Avatar
S550 4MATIC W221, W222, Lotus Elise
I checked mine. Pulled out one by one and one of them has oil inside the socket
There is no leak out to the outside socket and no check engine code yet. Will check with dealer for recall or I'll replace it myself.
Old Sep 28, 2012 | 09:57 PM
  #32
Em Bee Lover's Avatar
CL550 1976 450 SL
The SA @ my Wisconson dlrshp. emailed back to my query, precipitated by board discussion, that my S-550, a 2007, with production # 117,123 is not effected by this recall. Leap of faith, but I am not pursuing. Is there a production # where it is applicable?
Old Sep 29, 2012 | 10:50 PM
  #33
RT2010's Avatar
s550
Called my local deal (Atlanta) and they confirmed there is recall for my VIN. This is a pity 'cos I just changed 3 camshafts myself about 2 weeks ago - will be replacing all 4 again at the dealer next week.
$75.00 + time wasted!!
Old Sep 30, 2012 | 08:55 PM
  #34
CL550 1976 450 SL
Mind sharing the last six digits of your VIN? Thanks.
Old Oct 3, 2012 | 09:14 AM
  #35
mb1000's Avatar
Checked with my dealer and there is a recall to my car. My VIN is *103159 and covered by the recall . SA told me that MB is still sending out recall mail to owners.
Old Oct 3, 2012 | 08:24 PM
  #36
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
Definitely worth checking with your dealership..
my car is on the list...so they will take care of it when I am ready to take it in.
Old Oct 5, 2012 | 05:05 PM
  #37
Zuk's Avatar
Zuk
W221 S550 2007year
Good day Gents. Could you answer my question. Looks like I have a problem with camshaft solenoids I have read "M272 timing error" file and seems to be in "Scenario 2" (SD gives fault codes 0060 and 0064). My question is, is it dangerous for the engine when solenoids are faulty? Thanks for reply.
Old Nov 22, 2012 | 11:25 AM
  #38
mb1000's Avatar
What a recall, what an engineering solution !
Instead of replacing 4 solenoids, they just added an extension cord
(with better rubber seal on the connector) each and plug the oil leaking from solenoid. In 30min, my car was ready.
I'll replace solenoids myself.
Old Apr 3, 2013 | 03:38 PM
  #39
bonmozo's Avatar
2002 c230 kompressor coupe
hello everyone, I have the same problem with my 2003 c230 k, after having dealership replaced the solenoid harness, i replaced the solenoid but noticed that there's no seal between these 2 surfaces where the solenoid seats against the cam front cover, allowing oil to leak thru there. Does any one knows if this is an engineering flaw from MB? i asked SA guys and they said there's no seal in between. have any one here have this stubborn oil leak after all this work has been done? i forgot to say that i also replaced the middle oil plug in the new solenoid...any ideas how to re-invent their design????
Old Apr 3, 2013 | 05:49 PM
  #40
konigstiger's Avatar
'71 Pinto
Seal ring is 140 in diagram.
File Type: pdf
File Type: pdf
Old May 1, 2013 | 09:12 PM
  #41
voml55amg's Avatar
I check in for oil change today on my 07 s550 out of warranty :-)
My service advisor informs me about the open campaign for our w221.
They replaced cam sensor/wires at no charge. Also, SDS lowering is done too :-)
Ned
Old Aug 12, 2013 | 07:32 PM
  #42
Fahad.M's Avatar
s class 500
hey
Guys i would like to know more about this, Has any one knows the code number of the error when the light of the check engine is on ?
Old Aug 13, 2013 | 11:33 AM
  #43
'71 Pinto
Service Campaign Bulletin
File Type: pdf
Old Aug 13, 2013 | 04:34 PM
  #44
Fahad.M's Avatar
s class 500
thank you for the PDF
I went to a MB workshop and they checked my car there was an errors
looks please at the photo i guess is the same issue here, but the workshop said we have to take the engine out and woking on it takes 7 days !!
i'm totally surprised of that 7 days with no car !! also, there is no faulty symptoms while driving the car except the engine light is on !!
please help me to figure out the issue as it shown in the photo here with its codes ..
thank you
