Suspension Problem
Old Nov 2, 2012 | 03:11 AM
745Japan's Avatar
745i BMW '05, S550 '08
Suspension Problem
Guys I think my suspension pump is failing. During start up the car is fine. It will drive fine for awhile then the ecp malfunction light will come on with error. After it comes on the suspension seems to ride a little rough. I looked at the car and all the shocks seem to sit just fine, which leads me to think I need that pump and relay replacement. For you guys that had this problem, does my troubleshooting seem to be on track, if so please share your issue and what you did to replace the parts. Thanks again.
Old Nov 2, 2012 | 03:58 AM
745Japan's Avatar
Anyone?
Old Nov 2, 2012 | 01:13 PM
604benz's Avatar
2015 S550V
I had the same symptoms and replaced the pump and relay, not a big job around 1 hours labour.
Old Nov 2, 2012 | 06:42 PM
745Japan's Avatar
Thanks for the reply 604. Can you tell me where to access the pump and relay?
Old Nov 2, 2012 | 07:40 PM
604benz's Avatar
2015 S550V
The pump is located at the front passenger side of the car, jack up the car and take off the cover underneath and its right there.
The relay is on the drivers side engine compartment, i cant remember the number but someone on the forum must know.
