My Now "Matte White" S-class
Old Mar 29, 2013 | 11:52 AM
TDwayne69's Avatar
2012 CLS63 PP
Originally Posted by Arlen777
Well, one thing i personally consider if i would have 2012 S is that if you cut ur original mufflers, u ll likely have some issues with manufacturers car warranty.
Second thing is i have an aftermarket muflers+aftermarket replica S63 Tips, so i would just get exhaust tips only and diffuser, it would look like s63 and all the mods will be "cosmetical", so u ll less likely have issues with warranty
Hello Arlen,
Was there a specific reason why you didn't just remove the resonator from your OEM mufflers instead of purchasing a aftermarket muflers and removeing them? Just curious, because I'm thinking of removing the resonators from my OEM mufflers.
Do you or anyone else know of a reason not to go this route?
Thanks in advance,
Tony
Old Apr 14, 2013 | 10:20 PM
Fahad.M's Avatar
s class 500
great matte white, I'm looking to have black on mine but afried of that if take it out later it may causes any thing on the body ??
any way, please let us have a shot of your car at night :P
can't wait to see
Old Apr 18, 2013 | 03:37 PM
997.2's Avatar
W210 E320 4MATIC
trashy
Old Apr 19, 2013 | 02:29 AM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Originally Posted by TDwayne69
Hello Arlen,
Thanks in advance,
Tony
Well the only reason i went for this route is bc i heard a sound-clip of PHATISFY's car and wanted to have exactly the same sound. Well if you just cut-out ur resonators and keep your OEM mufflers, you are running the risk off ***king them up, bc resonators also lower the temperature of the outcoming exhaust. Like say engine puts out temp 1000 F, after its passed cats its 500 F, after Resonators are 250 F and finally mufflers take -in 250 F from Resonators and lower it to 100 F, if you cut out Resonators, then mufflers will take-in 500F instead of 250F.
2nd reason is because if you remove just mufflers it will sounds more like hot-rod.
can't wait to see
It depends on the material, if the place who does wraps uses cheap material it will likely leave glue behind it. The one used on my car is high-end brand thats specifically designed for the car, so nothing will happen to it
Originally Posted by 997.2
trashy
Constructive criticism much !?......
