12 Volt rear socket
Old Jul 7, 2013 | 08:35 PM
Atcpup's Avatar
S550
12 Volt rear socket
My 12 volt rear socket is not working and I cannot find which fuse it is. I located the sheet in the trunk that shows all fuse locations and it is not listed. I see the front and rear cigarette lighters fuses but not the 12 volt. Apparently the rear cig fuse is not associated with the 12v socket as the rear cig lighter still works. Any ideas or does any know which fuse it is?
Thanks!
Old Jul 8, 2013 | 10:59 AM
konigstiger's Avatar
'71 Pinto
Check rear SAM located in trunk behind left panel - f140 (15A).
Old Jul 8, 2013 | 11:30 AM
Atcpup's Avatar
S550
Konigstiger, you are such a huge asset to this forum....Thank you, that was it!
I looked passed that on the provided sheet 5 times, it's listed as center console socket.
Old Oct 13, 2013 | 06:03 PM
kamranraissian's Avatar
CLK500
Thanks so much Konigstiger. In my case, CLK500, it was fuse 21 which also was not listed.
