DRIVER AND PASSENGER WINDOW WONT COME DOWN
My drivers window wouldn't roll down so I had to spend $600 plus buckaroos!!! to get it fix,! now to find that the passenger side won't roll down...I refuse to pay $600 more to what I believe.is changing a fuel...but let the service people tell, they wear and tear...YEAH RIGHT,#
Anyone have this window issue???
If you don't want to replace it with a new one the other option is to have the trim panel remove and have the window-lifting motor also remove in the open but do not disconnect the cable.After removing,hold down the motor and let somebody actuate the switch in all position.If the motor is working then you can have it install back as it is already reset.
Hope these helps
