New Tires, Valve Stem Question...
2015 S550 4Matic
Hello all,
Quick question...when replacing tires on these cars, should the valve stems be replaced or due to TPMS is this typically not done?
Reason I ask is because I had 2 tires replaced by the local MB dealer due to imperfections/damage from the roads around here. Less than 48hrs later, one of the tires is down to 24psi and another at 36psi (despite being 39/40 when I left the dealer.)
I had this same problem on a car I owned previously due to the dealer not replacing the valve stems (eventually causing a blowout) and am wondering if MB should have replaced the stems while installing new tires.
Thanks in advance.
Thanks in advance.
Afaik you can remove the valve-stems from sensors. Looking at what these things cost I would say replace at all times ..At M-B your invoice should show these anyway??
Before installing new tyres I have the rims checked on the inside for any oxidation or damages.
My tyres I get from an expert Indy ,bc usually better deal ,as well as expertise.
