Looking for TSBs - can you post or email to me please?
2019 S560; 2019 Range Rover Supercharged; 1985 European model 280SL, Navigator Black Label, Lexus LX
I found some TSB notes in here - thanks to those who take the time to post them!
If someone has access to the actual pdf's can you please post these or email them to me?
Thank you!
I am hopeful these are what I need but there could be newer ones I suppose:
P-B-91.40/185 JAN09 221.171/176/177/179/186 up to VIN A199347 seatbelt height adjustment is nonfunctional the rivet which retains the pin for the cable of the seatbelt height adjustment mechanism on the seat rail may be broken. Resolve, pin attachment repair.
These next two may or may not be what I am after but I have the infamous creaking driver seat issues and since my warranty is now out I do not want to pay for a new seat frame. Hoping I can alleviate some of it myself.
P-B-91.10/147 MAR08 Cracking noises coming from the seat rails while traveling on rough roads, this may be due to not enough lubricant between the upper and lower rail at the end of the seat rail. Grease will be applied.
P-B-91.12/155 MAY08 Jarring/creaking noises coming from the bottom cushion, weight sensing seat bearing will be lubricated. If the noise persists, the seat-adjuster will be replaced.
Thank you!
