Accessory Power?
Old Mar 5, 2014 | 10:29 AM
ChesapeakeLimo's Avatar
2019 Maybach S560
Accessory Power?
I suspect this question has been asked/answered previously, however, I've not been able to locate a sufficient post…
Is there an accessory power tap in a fuse panel for hard-wiring 12-volt accessories such as dash cam, radar detector, etc. near the driver and/or rear seat? If so, can you specify the panel location and plug?
Thanks in advance.
Old Nov 15, 2015 | 05:34 PM
mustangy's Avatar
S Class 2007- 2010 - 2013 R 350 06
another thread the answer is must be easy and thosunds of folks read this forum for w221 which fuse can be used for dash cam or radar detector
for dash cam need a uninterrupted power when car is parking mode (no battery drain most of camera has power cut off at 11.8v)
http://forums.mercedesclub.org.uk/sh...ad.php?t=92240
front right cockpit fuses look like nearest box but don't know which one ?
Old Nov 15, 2015 | 07:03 PM
Mike5215's Avatar
2016 C300
Yeah I checked my 2010 and I just have a tap in the right dash panel for a hot connection ( cell phone charger). If you look in the spare tire well there should be a fuse diagram that will tell you which of those are switched. Or just experiment. The low amp fuses typically are switched (accessory).
Here's the hot fuse I use for always on:
The 2010 has a switched 12v outlet in the glove box so I use that for my V1.
I've also heard of guys tapping the cabin lights circuit right there in the rear view mirror enclosure.
Old Nov 16, 2015 | 12:58 PM
mustangy's Avatar
Thnaks Mike5215
yellow circles mark are power and ground right ?
awesome thanks this is easiest power source my guess.
awww you have a lot scratch there lol my guess you added a lot accessory there
i do understand but just make clear for other readers
but i just see another cables there whats is the fuse in extra yellow cover that i mark with red elipse ? and the other long black cable across all over ?
thanks again
Old Nov 16, 2015 | 01:01 PM
Mike5215's Avatar
2016 C300
The long black lead runs to the V1 up by the rear view. The other red goes into the glove box for a 2nd 12v outlet.
Old Nov 16, 2015 | 01:28 PM
mustangy's Avatar
thanks for instant answer mike5215
where the cables come out to dash i meant the route cables follow
if you can take pics thats will be a complete installation checklist
Old Nov 16, 2015 | 01:41 PM
Mike5215's Avatar
2016 C300
It's pretty straightforward. From the fuse box run up the fabric weather strip around the door jamb. At the seam where the headliner meets the A Pillar, pry the A pillar trim back far enough to tuck the wire in. It's tight. I use a butter knife to push the cable in. Pull the leading edge of the headliner down enough to tuck the wire in and run it across the top to the location on the windshield you want.
