Rear camera blue screen?
I would say the camera itself is bad.COMAND seems to be working and it's even drawing the colored lines on the screen.
The blue combined with no picture means the camera is either disconnected or dead.
You need an independent shop or dealer to plug it into STAR/DAS and look up trouble codes. There will likely be one for the wiring to the camera or camera itself.
Then you either replace the camera, repair the power wire, or repair the signal wire.
As a starting point, check if there is a camera fuse that has blown. Not sure there is a separate fuse.. it may be powered from COMAND.
If there is no separate fuse listed or the fuse is OK, you'll have to have it diagnosed. Something is up with your camera.
http://shop.reversingcamerasuk.com/I.../Fault-finding
Where to start looking? No idea. Likely the camera or some connector along the path.
Back in the day, they could only tell you what was wrong only at the time is was NOT working. Previous Mercedes...
Thanks, I knew at how this stuff works. I was just told once that these cars show everything with the dealers tools, but didn't know if it got this specific.
