airmatic strut pressure sensor
Old Apr 29, 2014 | 12:19 PM
terrymargate's Avatar
merdeces s320
Hi
I have 2011 (previously flood damaged) S550 that is sitting low on left rear.
Star diagnostics says it fails the test and that there may be a leak between the valve and the strut
it also shows me pressure on that strut at 0.0 bar (all others struts are showing fine)
Does this indicate that the strut needs replacing? Am just checking that the pressure sensor is on the strut and that the leak us unlikely to be coming form between the compressor and the strut itself.
if the loss of pressure is within the strut itself then I will cheerfully replace the strut to solve the problem
Terry
