Electric window stopped working - question about bulletin P-B-67.39/22
Old Jun 4, 2014 | 09:23 AM
wywywywy's Avatar
W221 S500 SWB
Hi all,
Basically my front right electric window stopped working, and I'm not sure whether it's the motor or the software, as described in the following bulletin -
P-B-67.39/22 MAR08 If the power window in any door is not functioning this may be due to a software error in the door control module. The applicable door control module will be flashed.
If it was the software in the door control module, what should I expect to see in the actual values in DAS?
Just want to make sure before I buy a new motor.
At the moment in DAS, it shows a "hall sensor error". The values of the switch is fine, and the value of the temperature sensor is 68 degrees celsius.
Thanks.
