iPod Interface Installation Questions
Old Mar 15, 2022 | 11:57 AM
  #201
404marc's Avatar
s550
Turning on Aux is great.. then the airmatic suspension pump will go, then the abs sensors, then the transmission etc etc...
Old Mar 15, 2022 | 12:16 PM
  #202
MBKarma's Avatar
2007 S65
Originally Posted by BOTUS
there is pretty much no way it can't display AUX - if they really turned it on - it will be on
you can enable before fitting anything, it will display, you can select and of course nothing happens as no sound is coming down an unconnected wire
Thanks. Apparently I'm not the brightest as a new MB owner and couldn't find the Aux function. I went to the local shop and they showed me where it was.
Can't tell if you're serious or not? These should not be related.
Old Mar 15, 2022 | 12:40 PM
  #203
404marc's Avatar
s550
joking....
Old Mar 15, 2022 | 12:42 PM
  #204
MBKarma's Avatar
2007 S65
joking....
Thank goodness. If MB had that type of glitch in it I would need to find another car...
Old Feb 8, 2023 | 03:33 AM
  #205
Maxfli's Avatar
2011 E63 AMG, 2007 S550 AMG
For those of you that have a s550 with no Aux in comand:
- Dashboard disassembly: 15 minutes
- Wiring hookup: 5 minutes
- Program interface that turned on Aux and another video Aux 20 minutes-- Aux works separately of Apple Car Play or Android Auto -
- Add Android Auto 5 minutes
- add12v switched to power bluetooth and power Android.
5 years on this forum and one person sent directions on how to turn on Aux, thx, but did not have a Star Machine..The foundation of getting, mp3, pandora, spotify, whatever to play!
404marc...I have a S550 with no Aux in the Comand menu and nothing in the glove box. Like you, I have read through this and many other threads looking for instructions on how to turn on Aux.
Can you clarify how you "Program interface that turned on Aux and another video Aux"? What did you use to program the interface to turn on Aux?
I'm trying to install an Apple Carplay unit (https://www.aliexpress.us/item/2255800863194291.html) and need the Aux input to do it.
Any help would be appreciated.
Thanks!
Old Feb 8, 2023 | 12:34 PM
  #206
BOTUS's Avatar
S500
the action required is simple - the easiest way is to got a a dealership and ask they enable - they use dealer diagnostic tools to get at the car via the obd2 port - its 10 minutes work to get to the right menu tick a box and say go.... they ought to do it for $50 or find a local garage with a copy of the tool and pay $30
Old Feb 9, 2023 | 09:02 AM
  #207
Maxfli's Avatar
BOTUS - Thanks for all the research/dialog/trial and error you've done on the ipod interface going back many years. It exhausted me just reading it! Not sure I would have endured what you went through for that long...
FWIW, I put a bluetooth Apple Carplay unit in my '11 E63 last year and it works seamless/transformed the nav, phone & music options/brings the car current from an audio tech perspective. I had to enable AUX in the engineering menu and rewire the AUX into the main audio connector to get it to work and it was pretty easy to install overall.
The '07 S550 looks just as easy...the only challenge has been enabling AUX. I know I'm going to have to pay to get it done...I just can't find anyone that knows how to activate it in STAR. So far, I've tried two independent MB shops and neither knew how to do it. One said if I had directions or screenshots they could follow, they would be able to do it because they have all the same diagnostic tools as the dealer. The guy was being honest and didn't want me to have to pay for his time hunting around trying to figure it out. I've got a few other independent "German" specialist shops left to try before I head over to the dealer.
Anyway, I'll get it done. Thanks again!
Old Feb 9, 2023 | 01:19 PM
  #208
BOTUS's Avatar
S500
well they are idiots then - its simple as.... go to comand tick a box - mine was done for free
if you go the route of modern stuff I don't think you use Aux.. you just long press a button to flip into the new world
10 Connect STAR DIAGNOSIS
11 Perform retrofit variant coding Perform variant coding with Star Diagnosis to activate the AUX function of the COMAND.
12 Close STAR DIAGNOSIS
13 Carry out function check Check iPod functions as per iPod operating instructions in vehicle.
Old May 22, 2024 | 04:28 PM
  #209
charlesb2003's Avatar
2005 E320, 2008 E320 Bluetec
Sorry to bump an old thread, but does anyone know of a good source for the B6 782 4531 cable or equivalent? Mine is frayed and I've searched everywhere with no luck.
Old May 22, 2024 | 08:43 PM
  #210
MBKarma's Avatar
2007 S65
I have one and I've been holding on to it just in case to use it if I can't find a good Android car play System. Do we know what the best car play system is available out there as of today? I could go install it and if all works well just sell you my cable.
Old May 23, 2024 | 07:49 AM
  #211
I'm not sure what the best Android Carplay system is for the W221, but if I had one I'd be looking into doing this:
I've always been a big fan of Dynavin, but I did a quick search and sadly it doesn't look like they make anything for the W221.
If you end up doing that I will gladly buy that extra cable off you. Just let me know!
Old May 23, 2024 | 03:09 PM
  #212
MBKarma's Avatar
2007 S65
I'm not sure what the best Android Carplay system is for the W221, but if I had one I'd be looking into doing this: https://www.youtube.com/watch?v=xiBu9t0N0TU
Did some research today and it looks like 4x4 Shop's and Chris the Swede's systems are two of the top systems. I may order one here soon.
How soon would you need the cable?
Old May 23, 2024 | 03:12 PM
  #213
That's good news! I'm in no rush, but I'm ready when you are. PM me so we can work out payment once you've got your new Android system installed and well tested. And don't forget to post pics for us all here!
Old Jun 23, 2024 | 09:59 AM
  #214
sapidus's Avatar
2008 S550, 2015 G550
Can't find B67824531A; will this work?
My 30-pin iPod cable (2008 S550) is perished; part B67824531A, below. It's no longer available new or used. Would this work? https://www.get-console.com/shop/en/...ouch-rj45.html
Old Jun 23, 2024 | 11:46 AM
  #215
Jaap's Avatar
2006 W221 S500L M273
@sapidus I'd be surprised if that pin mapping is the same as Mercedes'.
There's no standard for this so they could have connected all the pins differently.
Old Jun 23, 2024 | 01:05 PM
  #216
sapidus's Avatar
Great point, I hadn't thought of that. Are these iPod cables repairable, e.g., perhaps just loose connections on the 30-pin end? Or do I need to scour ebay for the next few months?
