S600 TCU - M gear hold and heating tire question
Old May 8, 2015 | 04:27 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I have a 2008 S600 and have received a few different reports regarding a TCU program or swap to achieve AMG functionality. I know the IC can be version coded to provision M mode with the existing TCU, however it does not actually hold the gear as M mode is designed to do. It will stay in gear until redline but then forces a shift.
Also, I was wondering what peoples experiences were heating drag radials at the track? It seems that ESP will intervene and prevent this, even when disabled, and dyno mode really does not provide the desired effect either as the car will not shift into 1st gear (from what I understand by design).
Thank you
Old May 8, 2015 | 04:33 PM
WHPH28's Avatar
Depends on the weather
He heats these up pretty good...although not stationary, I'm sure it's the same.
Old May 8, 2015 | 04:38 PM
Polar Bear's Avatar
2007 Mercedes S600 Burnout with Renntech & Carlsson upgrades by GMP Performance - YouTube
I saw that when looking for a solution. It would be hard to use that technique at the drag strip, though
Is your S600 a 2007 (guessing by the SDARS antenna)?
