IC re-marry
Old May 12, 2015 | 01:59 PM
khtruong0615's Avatar
2007 s550 4matic
IC re-marry
There is a service told me if my used IC from Ebay can be zeroed out the mileage then I can adapt to my car and update the mileage from the car to the correct one, is that true? because I though once it is married to a car you can not adapt it to a different car.
Old May 12, 2015 | 03:43 PM
konigstiger's Avatar
'71 Pinto
Correct, you will need MB DAS to complete the task + SCN coding may be required.
Old May 12, 2015 | 04:52 PM
2007 s550 4matic
Thanks. Do you know if there is hardware and software that can do the zeroing? Or is it possible to de-solder and move the Eeprom?
Old May 12, 2015 | 05:48 PM
'71 Pinto
Mercedes-Benz Xentry Diagnosis Software (DAS)
Old May 13, 2015 | 05:00 PM
alx's Avatar
alx
I believe mileage can be legally manipulated via das once and in a very narrow range.
Old May 13, 2015 | 08:45 PM
2007 s550 4matic
My main odometer is 0 because I just installed a brand new EIS with no data transferred from my old damaged one. My bought-used IC is 80000 some and I could not find in any menu where to zero it out. My IC now just show ------. Wonder if I can change my EIS to match the IC then file a report for not accurate mileage.
Old May 14, 2015 | 10:35 PM
2007 s550 4matic
Had a odometer man came over and rolled back the meter to 98 miles through OBD and did the teaching to authorization system. It shows the mileage now.
