I cut out my mufflers and...
Old Jun 5, 2015 | 04:40 PM
REL_'s Avatar
2010 S550
It sounds very very similar to this but better.
Old Jun 5, 2015 | 07:32 PM
Mike5215's Avatar
2016 C300
Originally Posted by REL_
Car is in the shop, will have to wait about 2 more weeks.
Sorry guys! It's a nice deep rumble sound (NO DRONE) but the gas mileage went down too much. I'm averaging 9 mpg city since I did it.
I'll post a video before I put it back to stock or replace the mufflers with something else.
Shouldn't mpg go up with the reduced back pressure? Should run cooler as well, right?
Old Jun 5, 2015 | 07:50 PM
REL_'s Avatar
2010 S550
You'd think but I guess the back pressure helps with mpg on the S class. It's down significantly even with light driving so I'm going back to stock or the Becker I'll decide when I get my car back.
Do you have any videos of your car while moving? You have the Becker exhaust or did you add something with it?
Old Jun 6, 2015 | 09:21 AM
hyperion667's Avatar
2012 CLS63
would be nice if it was an AMG.........but it isn't
Old Jun 6, 2015 | 09:59 AM
F1BHP's Avatar
sl600
Are you thinking a lack of back pressure is causing the low MPG?
Edit, sorry I didn't read the second page
Old Jun 6, 2015 | 12:06 PM
Mike5215's Avatar
2016 C300
Becker and then two in line 18" glasspacks. I can record from the cabin while moving. Not sure how I'd get the moving external sound, but my kid is a TV producer so I bet I could figure it out.
Old Jun 6, 2015 | 12:09 PM
  #32
Mike5215's Avatar
2016 C300
Everything is so much nicer when it's authentic AMG. Really the right way to do a quad exhaust is to buy a new or salvage S63 exhaust. Pricey though and you'd never recover that money.
Old Jun 7, 2015 | 07:02 PM
  #33
REL_'s Avatar
2010 S550
You can place your phone or recording device on the ground and just drive past or park near it and rev a few times
Old Jul 24, 2015 | 07:45 PM
  #34
Zerocarpileup's Avatar
2008 S63
The X pipe is just forward of the rear axle and takes the two outputs from the exhaust headers and sends it back out to the mufflers. It's about 3' long. The shop just cut it out then made two straight runs to the mufflers, splicing the resonators into the straight pipes in the process.
The pipe on the muffler and chassis is 2.4. I can't find resonators with 2.4 inlet and outlet anywhere. I do see 2.25 and 2.5 would a 2.5 resonator be too big to weld on properly?
Old Jul 24, 2015 | 08:32 PM
  #35
2008 S63
We might have different exhaust layouts because I don't see an x-pipe anywhere. This is a bad pic from the rear because I don't have a lift but I don't see an x-pipe anywhere.
I'm trying to order the resonators online before I show up at the shop. I don't want to use any old resonator they have on hand. I found some that are specifically made reduce noise.
Does anyone have a picture of the underside of a 2007 base? I received the exhaust but now I'm confused as to which resonators I will need. Even more confused on where to cut.
