A/C not working
I would first put a pressure gauge on the low side to verify the sensor reading. As a shot in the dark, have you tried resetting the modules (disconnecting battery)?
You can also disconnect the sensors to see if the SAM throws an error (as you would expect). This may give you a clue to something?
I think my main problem is I have no voltage out to sensors from Front SAM but don't know if something disable them or my SAM is bad. I'm going to try to tap the multifunction sensor to the battery 12 volt to see if I have some reading. Do you know any 5 volt wires in the Front SAM or near by for the pressure sensor?
It's unusual for the lead powering the sensor to be 5 volts. How many wires are going to these sensors? Power, ground, and return (sense)? Another silly question: Have you checked the fuses?
