Engine vibration at 1500RPM
Old Jun 28, 2015 | 06:24 PM
caperss's Avatar
2010 S550 4Matic, 88 560SL, 2002 Boxster, 2005 Jaguar Super V8
I have an annoying vibration from the engine at 1500RPM on my 2010 S550 4Matic with 60k miles above or below that RPM it is smooth as silk. I can reproduce this vibration in park so it has nothing to do with the drivetrain. I suspect one of the accessory pulleys or idlers. So far I cant narrow it down my question to the Forum is, what is the most common failure so I can look in those areas? My first guess would be an idler bearing but have any others had problems with any other bearings failing, IE alt, water pump or AC compressor etc.
Old Jun 28, 2015 | 06:31 PM
alx's Avatar
alx
I would start by looking at the the engine and tranny mounts.
Old Jun 28, 2015 | 06:40 PM
Larry1979's Avatar
2011 S63 AMG Designo Performance P3
I experienced an issue similar to yours on my 2011 S 550 and after conducting research, it appeared that my issue was the idler pulley due to several other owner's experience with this vibration issue and the idler pulley being the cause. I took my car to the dealership and told them I believed the issue was the idler pulley and needed them to check it out. It turns out that my issue was a bad belt tensioner. After the belt tensioner was replaced, the vibration stopped. I had approximately 28K on the odo when the belt tensioner failed. I would try the belt tensioner or idler pulley.
Old Jul 1, 2015 | 06:45 PM
robohopar's Avatar
2016 Mercedes S550
check the motor mounts for sure...the culprit for my engine vibration at idle was one motor mount(left)
