Significant differences between 07-09 & 10-13 models?
I'm aware of the transmission woes of early 07's, however are there any significant improvements beyond cosmetics that make the later years that much better?
TIA
https://mbworld.org/forums/s-class-w...2010-s550.html
https://mbworld.org/forums/s-class-w...ut-buying.html
https://mbworld.org/forums/s-class-w...vs-2010-a.html
https://mbworld.org/forums/s-class-w...2009-s600.html
I have, most if not all of the threads focus on cosmetic updates. One thread mentioned minor software changes but it pertained to the s600. Just wanted to be sure.
there is no phone call Bluetooth connection in the early ones (you can play adding extras to get there, but its not std - although there is a BT connection for a headset !!!)
with the right option code you get Bluetooth music streaming in later cars
the navigation is a better system and higher def screen.... however USA maps are dead. in Europe they still do map updates for the early cars but the NTG3.5 has been dead since 2015 re newer mapping …. which is mad as the info is on the earlier discs ???
