Replaced battery
Old Dec 30, 2015 | 03:10 AM
Christap326's Avatar
S500 Mercedes benz
Replaced battery
My battery on my s500 was dead. I left it sitting about a week. I replaced battery two days ago and now my locks don't work with they key. The trunk won't open unless I use fob key, my steering wheel doesn't move when I start the car or shut it off. When I press the lock button on my key the lights flash but nothing happens. When I press unlock it does the same. My hazard lights stay flashing. ...help plz
Old Dec 30, 2015 | 03:12 AM
S500 Mercedes benz
Also the fob key doesn't unlock or lock doors. If I hold it in key hole and hold it to the right my windows roll down.
Old Dec 30, 2015 | 11:07 AM
DaveW68's Avatar
Veteran: Army
2015 S550
If you're able to start the cat ok, then your accessory battery in your trunk is likely fully discharged. You will need to drive around for an hour or more without shutting off the car to recharge it. If that doesn't get things working, then that battery is too far gone or you likely have an issue with your alternator or voltage regulator.
Old Jan 1, 2016 | 12:13 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Christap...what year S500
Old Jan 1, 2016 | 02:34 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
I just got "replace key battery". Anyone know what type of battery the remote takes? I'm sure ebay has a pack of 5 for cheap.
Old Jan 2, 2016 | 05:50 PM
Nuru's Avatar
S350 BT 4MATIC
I think it is either DL2032s or 2025s
Old Jan 3, 2016 | 07:21 PM
wilassasin's Avatar
2013 S550 4matic (AMG sport package), 2016 Corvette Stingray.
Nuru is correct.....2025s
Walmart has them, 2 pack for $5.
Old Feb 2, 2016 | 11:45 AM
Jason B's Avatar
Did some checking and everyone should replace with the 2032 battery. It holds more MAH and it gives a better range and should last longer.
http://forums.mercedesclub.org.uk/sh...ad.php?t=60506
Old Feb 2, 2016 | 12:33 PM
1bad540's Avatar
s550 Diamond white amg pano
around me they sell those at most of the gas stations.
Old Feb 2, 2016 | 12:40 PM
Jason B's Avatar
Yea, I ordered a 5 pack on ebay for $1.99. Just realized my garage door opener takes the same ones.
http://www.ebay.com/itm/171868117505
Old Feb 2, 2016 | 12:44 PM
1bad540's Avatar
yea pretty much everything takes those now, I think my wireless alarm takes them too.
Old Feb 2, 2016 | 01:12 PM
DaveW68's Avatar
Veteran: Army
2015 S550
I think you mean 2032, correct? I don't think there are any 2035 batteries.
Old Feb 2, 2016 | 02:02 PM
1bad540's Avatar
yea I think cr2032 is standard?
Old Feb 3, 2016 | 05:34 AM
wywywywy's Avatar
W221 S500 SWB
Wait, 2032 and 2025 are interchangeable?!
I never knew :O
Old Feb 3, 2016 | 08:37 AM
Jason B's Avatar
Whoops, I mistyped. Yea 2032. The stock battery for our remotes is a 2025. The 2032 is slightly thicker but will still fit luckily. The other post I linked to above shows others getting longer range from the remote and longer battery life due to the extra mah in the battery.
