Vibration at 70mph 2012 S550 Airmatic 57k mi.
Old Jan 16, 2016 | 12:25 AM
Donnymac's Avatar
63 Falcon vert
Vibration can be felt in seat and steering wheel. Vib is fast short cycle. Does not get worse with speed increase. Much more noticible when off the gas at 70. Vib diminishes when on the throttle.
What are symptoms of motor/trans mounts?
Feels like a worn out u-joint.
Have not tried force balance or wheel check.
I searched the threads. Lots of info but didn't find anything on target.
All comments welcome.
Old Jan 16, 2016 | 11:48 PM
alx's Avatar
alx
Roadforce balance wheels. Cheapest but if vibration is present in steering wheel and seat it is not it or you have bad tires front and back.
Check engine/ tranny mount. As you go 70 toss tranny in neutral. Vibration gone? Mounts.
Still there? Check driveshaft rubber cakes. Still present?
Check driveshaft balancing weights for missing ones
Old Jan 17, 2016 | 12:26 AM
Donnymac's Avatar
63 Falcon vert
alx thanks. I will start your process mañana.
Old Jan 17, 2016 | 10:53 PM
Donnymac's Avatar
63 Falcon vert
Alx all I could do today was road test the car. On smooth blacktop with tpsi f/r: 37/38. At 75 with vib, dropped to N and coasted till vib stopped at 60. Vib was max at 68-70. Gone at 60.
Ran that cycle multiple times.
Most definitely not motor rpm related. No vib from 800 to 4000rpm.
Will investigate more when I get home this week.
Thanks for the help.
Old Jan 18, 2016 | 04:44 PM
alx's Avatar
alx
my gut feeling is that you just have a bunch of out of balance tires...
Old Jan 18, 2016 | 10:26 PM
Donnymac's Avatar
63 Falcon vert
Setting up road force balance mañana.
Thanks.
Old Mar 23, 2016 | 10:34 PM
Donnymac's Avatar
63 Falcon vert
Vibration Road Force update
Alx - Finally had the road force balance done. Bottom line, both front wheels are visually not true. Never have I bent wheels before.
Just how soft are OEM wheels?
Old Mar 23, 2016 | 11:08 PM
alx's Avatar
alx
Oem are the strongest wheels in my experience...
Old Mar 24, 2016 | 01:28 AM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
Possibly a bent wheel.
Old Mar 24, 2016 | 01:30 AM
Not on the E class.
Old Mar 24, 2016 | 01:47 AM
xpl0sive's Avatar
CLS55 AMG
both of my stock 19" AMG wheels are bent on my S550 too. I was surprised, never bent a stock wheel before
Old Mar 24, 2016 | 03:49 AM
Donnymac's Avatar
63 Falcon vert
Time to do a little shopping. Alx thanks.
Any OEM wheel options to consider?
Old Mar 24, 2016 | 07:12 AM
boltonblue's Avatar
15 AMG S63 4-matic coupe
Depending on how badly it is out of round, you can get the wheel trued and brought back into spec.
I've done it a few times with good results.
Old Mar 24, 2016 | 07:32 AM
egalt's Avatar
2011 E350, 2007 CLK350
Yeah, I just went through the same issue. Looked like a piece of snow....was a rock. Had wheels straightened...problem solved. Avoid road hazards, or you may have to do this frequently
Old Mar 24, 2016 | 06:55 PM
Donnymac's Avatar
63 Falcon vert
For now, that is the plan.
Old Mar 24, 2016 | 11:40 PM
I have had that done several times over the years with the first two sets of OME rims I ha don my E class. They can only be heated and bent back round once maybe twice. More than that the wheels aren't safe. I threw in the towel and went down to 17's and a nice set of General Altima tires. The car rides MUCH nicer now. I miss the look of my chrome wheels. They really made the car pop.
Incidentally since I am in the market for an S class I did ask my wheel guy if the S class and it's 19" wheels are subject to the same issues as the E class. He said no, not as much. In his experience The E classes and BMW 5 series suffer the most damage to their wheels due to the off set and the very low profile tire. The S class has a bigger tire suited for city use.
The NYC/NJ roads are terrible.
Old Mar 25, 2016 | 12:22 AM
Donnymac's Avatar
63 Falcon vert
For the first time we have a pot hole explosion in hwys all due to record rainfall and unprecedented ballooning oil field heavy traffic. Normally our roads are great. Now it's 2+ years of remaining road repairs. Typically we drive ducking deer and coyotes. Now pot holes are on the list.
Once I get a 5th wheel/tire, I will start the wheel repairs. My concern is after the repair, what is wheel integrity like. Compromised or not?
Old Mar 25, 2016 | 10:38 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
^My E has the same problem and the tire can be safe if only repaired once for sure. Anything after that can get a lil suspect.
Old Mar 25, 2016 | 04:45 PM
alx's Avatar
alx
Blah. I have yet to see tire fail where it was repaired as long as not on the sidewall. Your mileage obviously may vary.
Old Mar 25, 2016 | 10:36 PM
Not so much tire failure, but the wheel can and will become bent again because the repair does weaken the wheel a bit. Bent wheels can lead to side wall tire bubbles that can cause tire failure.
Old Mar 26, 2016 | 09:00 PM
alx's Avatar
alx
Ah you are talking about rims. Agreed. Once bent it will bent again.
Btw, I have the 20" Amg package on my 221. I have bent all four oem wheels. Finally I said f it and went with 19. Soooo much better ride and zero bent wheels.
Old Mar 26, 2016 | 10:34 PM
Donnymac's Avatar
63 Falcon vert
If you bend 20s and not 19s and I bend 19s, I Would never survive with 20s which was my plan to switch to. That ends that.
What is your psi after tires are warmed up?
Old Mar 27, 2016 | 07:54 AM
egalt's Avatar
Ok, I give....how is it that you don't bend 19s?
