Front end dropped. Bad Valve Block
I suspect it isn't the air shocks because what are the odds of both going bad, the same goes for the height sensor. So I ordered a valve block on ebay for $150 and hopefully it is the problem.
Any write ups on how to replace the valve block?
Update, turns out the compressor is dead. Replacing it along airmatic compressor filter as well as valve block, relay/fuse.
