Brakes repair
Old Aug 8, 2016 | 11:29 AM
donwal49's Avatar
2008 mecedes s550
Brakes repair
When replacing the brake pads on my 08
s550 is it necessary to remove the master cylinder cap and why?
Old Aug 8, 2016 | 12:12 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
To prevent overflow/over pressure when the calipers are compressed
Old Aug 8, 2016 | 12:41 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
You should never compress your old fluid back into the master cylinder. The proper way to compress the caliper is to bleed it as you compress. The calipers tend to collect the most debris and contaminants and you don't want this in your system. When you are done with the brake job check the fluid level and top off if needed. I usually bleed the brakes at the same time as it is pretty easy to do.
