Heat vents blowing cold air
Is this a easy DIY, any info appreciated.
https://www.amazon.com/Mercedes-CL55.../dp/B009PQ7YFE
I have S500 (with rear climate control) - ordered this part (by VIN) from dealer and I cannot find this under hood.
Do you have any pictures and can you post them or PM me ?
Have issue - I set 16C (cold) on the read - it sending hot air, set 28C (hot) sending little warm.
p.s. I checked duo-control valve located behind right front whell (replaced it becuase on SD there was an error of this valve - after removal one of valves was damaged) still the same.
Thank you,
Mariusz
Here's a link
http://www.benzworld.org/forums/w221...ue-only-c.html
