Cylinder Misfire
Cylinder Misfire
Brand New manifold installed and takes care of engine misfires for 90% of the time.
What else could be causing cylinder misfires?
It used to be 6 and 8 cylinders now its 5 and 7.
very strange
very strange
Unfortunately there are many causes for cylinder misfires
- vacuum leaks (should have eliminated those with manifold change)
- coils, wires, spark plugs, ignition power supply
- injectors
- lack of compression
- camshaft timing
Believe the early 550 engines had some wear issues with timing idler gear. Did the shop eliminate that?
- injectors
- camshaft timing
- injectors
- camshaft timing
- injectors
- camshaft timing
