2007 S550 Failed Mechanic transmission oil change HELP.
Pre-facelift vehicles call for one time transmission service (fluid change) at 39,000 to 40,000 miles. Check the service manual for the your model year. Service manuals are downloadable from mbusa.com
That is awfully nice of you. May I ask where you got your system from and what did it cost you? Are the Chinese sellers any good?
I have a 2007 S550 with 130K miles. I bought it at 70K miles and don't know if the previous owner got a transmission flush at any point of time. According to manual, transmission oil supposed be changed at 39,000 miles. Car is running fine and does not have any problem. I was told that if running fine - do not change, because it sometime can cause more problem to transmission. Do you have any recommendation, good or bad experience after transmission oil change.
#32
always change it the bits will wreck the box
the Indy specialist I use claims the electro plate failure (that's normal) is exacerbated by dirty fluid
the solenoids pictured above don't like the metal debris as it rips up the seals inside
the TC lock clutch failure also worse with dirt in the fluid
basically it might last longer if you change it..... and they need all the help they can get.... trans fluid has been through three revisions trying to help.... if anything mine changed worse after the fluid was changed...
when I asked if it needed doing at 42k he said if its 10 years old it will be black and horrible.... IT WAS with more gunk in it than all the **** I took out of RR and Jags gearboxes put together in 10 years on the spanners !
