Bad battery?
dealer most likely will quote you for around $350-400 id guess
Sam's club has it. When I called them before I posted, they said they didn't, but they do. Two choices. Again, this is for 2010-2013 S550 with ONE battery up front, both 3 year free replacement:
http://www.samsclub.com/sams/duracel...prod3590267.ip
$119
Specifications
Battery Electrolyte Composition:Acid
Battery End Type:Top Post
Battery Purpose:Starting Lighting Instrumentation
BCI Group Size:49
CA at 32 degrees F:1105
CCA at 0 degrees F:900
DIN code:H8/L5
Freight Class:65
Polarity:Right Positive
Reserve Capacity:185
Terminal Type
IN/SAEVolts:12
OR
http://www.samsclub.com/sams/auto-gr...uestid=4375412
$169
Specifications
20 amp hour rate:92
Battery Electrolyte Composition:Glass Mat
BCI Group Size:49
CA at 32 degrees F:975
CCA at 0 degrees F:850
DIN code:H8/L5
Freight Class:65
Reserve Capacity:170
Terminal Type
INVolts:12
remove and replace
just dont overtighten the terminals
saved yourself two hunnid
I think it has more power than the OEM specs, the new AGM aftermarket. I'll admit I miss the looks of Mercedes branded battery a little, (that's just my **** self) but like the quicker starting.
EDIT, this battery from Sam's has 3 year free replacement, at the $169.
Do the 2011s have this under dash accessory battery? I keep reading different answers and really just want an honest one
