Battery issue?
Battery issue?
My 07 S550 was shipped from VA to CA. The car sat for 5 days without been driven. When I start the car, the red battery light is on, and the ESP and ABS lights are on as well. The steering is very hard to turn, I can barely steer the car. Also, center console screen keeps flickering.
I'm guessing the battery in the truck went bad. Could this be a bad battery issue?
Location: Land of Political Criminals and Urban Shootings
2015 S550
If a new accessory battery doesn't fix the COMAND flickering and warning lights, then something else is going on and will likely need a dealer diagnosis.
Hopefully the shipping company didn't do some damage to your car during the loading or unloading process.
Thank you. So I decided to a little visual diagnostics. Upon looking under the hood, I noticed the serpentine belt is completed shredded. Could the broken serpentine belt be reason for all those malfunctions, including the hard steering wheel?
The serpentine belt drives the power steering pump which would explain your hard steering. It also drives the alternator which could prevent recharging your battery.
