No backup camera after replacing command unit
Old Sep 9, 2017 | 04:51 PM
Eppscobar2211's Avatar
s550 4matic
I have a 2007 s550 and I just recently replaced the command unit and now I have no backup camera, it is set on the display to come on when in reverse but i'm still getting nothing. Would I need to reprogram the camera?
Old Sep 9, 2017 | 05:02 PM
konigstiger's Avatar
'71 Pinto
May need to code using MB SDS, see if this helps.
Code COMAND: Control units - Information and communication - Audio, video, navigation and Telematics - COMAND - Control unit adaptations - read coding and modify if necessary - display all COMAND codings. The coding must be set as follows: Rear View Camera installed: YES - Reversing camera: Camera with Parking assist if the coding is not set as specified press F2 to return to the previous menu and select the item "Set vehicle and equipment dependent codings automatically. Run through the subsequent steps and check the codings that both, Camera and Parking Assist are selected.
