windshield washer pump
Is there a video of the replacement of the windshield washer pump for 2012 S-Class. How to remove the reservoir that the pump is attached to. is there only the one bolt that holds the reservoir in place? Thanks
I did it a couple years ago. From what I remember...
the washer pump can be accessed from the driver side wheel well. If you don't want to put the car up on jack stands and remove the tire, just turn the wheel to move it out of the way.
Pull out the plastic grommets on the wheel well cover. Peel back the cover and you should be able to see the washer pump. It plugs into the washer fluid tank and there is an electrical connector to unplug. Best to do it with a low washer fluid reservoir so you don't get too wet.
I bet Konigstiger has answered this before with a PDF from the MB repair manual. Search the forums.
