Air Strut Boot
Old Nov 6, 2017 | 07:10 PM
survey1's Avatar
2012 S550
Air Strut Boot
I have a torn air strut boot on my 2012 S550 but the strut appears to be working fine. This appears to have torn recently.
Is it possible to replace just the boot and not the entire strut assembly?
If yes, would this be covered by MB CPO ELW? I see on the inclusion line under "SUSPENSION .........air suspension struts" but it doesn't specify boot.
If no, would you bother fixing it or just let the strut blow up and then at that point it would be covered by warranty??? If I'm reading the warranty terms correctly the warranty DOES cover the entire strut but DOES NOT cover just the boot - yet replacing the boot would prevent the strut from failing?
What is the part number for the repair kit or list of parts needed for front drivers side?
Old Nov 7, 2017 | 09:47 AM
konigstiger's Avatar
'71 Pinto
MB does not offer a repair kit. Torn boot should qualify for strut replacement under warranty. Original strut installed at production is replaced with new part # (usually indicating modification) so I would suggest requesting replacement. See attachment for current part #.
Old Nov 7, 2017 | 06:07 PM
S430AMG's Avatar
2006 S430 AMG
It should be covered and replaced. There is no way to replace the boot.
Old Nov 16, 2017 | 07:39 PM
survey1's Avatar
2012 S550
Dealer is giving run-around for repair claiming the part hasn't fully failed yet. I have service manager challenging with MB to get it approved.
Old Nov 26, 2017 | 02:37 PM
survey1's Avatar
2012 S550
They finally approved the repair after argument.
