Any DIY on how to change motor and transmission mounts on 2013 S350?
Old Nov 7, 2017 | 04:59 PM
Diesel101's Avatar
2013 S350 Bluetech
I have been searching for a while and can't seem to come up with a solution. Would someone please direct me to where I can find a detailed write up or better yet a video on how to change the 2 engine mounts and the transmission mount for a 2013 s350 ?
Thanks,
Old Nov 7, 2017 | 06:06 PM
S430AMG's Avatar
2006 S430 AMG
Transmission mount is similar to just about any other Mercedes out there. Ceck out Mercedes source video, that will give you a good idea of what's involved.
Engine mounts are a bit more involving, I wasn't able to find much but I'm sure the info is out there. Search for W220, it seems like there is way more info on this model vs W221 and they are very similar.
Old Nov 8, 2017 | 12:23 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Engine mounts vary somewhat between all the models but essentially, loosen and remove the top mount bolts, jack up the motor and then remove lower bolt and R&I the mount. For specific instructions to you car, you must post your vin.
If you are going to be doing your own work then a must have is a copy of the WIS/EPC program to refer to. A set of DVD's can be purchased on ebay very reasonably. That is what most of us DIYers rely on.
Good luck,
Bob
