Rearview Camera Issues
Old Nov 9, 2017 | 10:12 PM
604benz's Avatar
2015 S550V
My 07 S550 rearview camera is playing up, lately when I put car in reverse it will show a blank screen for a second then go to command display, also when in drive the screen will show blank reverse camera, I have to manually put the screen back to command.
I have read there is a wire in trunk that breaks and causes this, has anyone had same issue, if so how did they fix, anyone have the part number for the wire.
If anyone has fixed themselves, can I get a DIY write up.
Any info appreciated
Old Nov 12, 2017 | 03:24 PM
604benz's Avatar
2015 S550V
If anyone has this issue, its a easy fix, my camera wire was broken at the trunk hinge, i just cut and connected new wire and working again.
These are some links i found that helped
https://drive.google.com/drive/folde...Dg?usp=sharing
Old Nov 15, 2017 | 02:10 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Did you get a BLUE screen?
Old Nov 15, 2017 | 06:52 PM
604benz's Avatar
2015 S550V
I believe my screen just went black not blue
Old Jan 8, 2020 | 09:05 AM
Woojin's Avatar
W221 m37
Blue screen w221 2010
When it is cold outside, rear view camera doesn't work and show blue screen. Must I change the camera?
