U.S. spec 2010+ headlights
So I found a video on YouTube in which the headlights turn with the front wheels when the car is not in motion or is at low speeds, along with the cornering lights, is this a Euro spec option only? Because I noticed my cornering lights only come on from 0-about 30 MPH, and the low beam projectors turn with the wheels at speeds of about 35+. Couldn't find any info on this.
Thanks.
Thanks.
Note this from the current build info on MBUSA.com
Pioneered by Mercedes-Benz, dynamic full-LED headlamps generate light that's even closer to natural daylight than Bi-Xenon headlamps. Active Curve Illumination and Adaptive Highbeam Assist continuously vary the beam pattern of the LEDs in each headlamp to help maximize the illumination of corners and straightaways, without creating glare for other drivers. Corner-illuminating front lamps, actiated by the steering wheel or turn-signal use, brighten your way into driveways and garages. Except the cornering lights on my 2018 GLS450 seem to be missing and the dealer is trying to find out why???
Location: Land of Political Criminals and Urban Shootings
2015 S550
Maybe you have some sort of error with your lights. Because my lights will turn at just 5 mph, perhaps less. The faster I go, the greater the turning radius.
