Pleas HEALP!! Instrument cluster to AMG
Old Dec 6, 2017 | 05:27 PM
sizzer's Avatar
S320
How can I change my s320 to AMG instrument cluster?
I found some here, but i canīt see the pictures.
( https://mbworld.org/forums/s-class-w...uster-amg.html)
Pleas HELP! Thanks
Old Dec 12, 2017 | 11:17 PM
user 58362638's Avatar
https://www.revtronic.com/product/me...luster-to-amg/
Hope this helps!
Greg
Old Dec 22, 2017 | 12:49 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
You would need to find a professional that knows how to flash the EEPROM in the instrument cluster, and also already have the image, or the addresses and values, of the AMG setting. This setting is not simply connecting to a dealer diagnostic machine and changing - it is changed at a much higher access level than what dealer diagnostic machines are authorized to do.
You have two choices - the S63 cluster, a 200mph speedometer, or an S65 cluster, with a 220mph speedometer. Keep in mind the tachometer, fuel, and other gauges would then not have the same font as the AMG LCD speedometer, (which has a red needle). You can also change it to a BRABUS speedometer if you know what you are doing, which uses the same font as the standard S-Class, but with a 220MPH scale. You could send it to me and I could do it for you if you really wanted it.
Here is the BRABUS speedometer:
