How to replace brake discs/rotors and pads
Old Jan 13, 2018 | 02:04 PM
quincross's Avatar
2002 E320 CDI
Originally Posted by atikovi
I'm ready to go with new front and rear rotors, pads, sensors and fluid.
The whole hog? Front, rear and fluid flush by the looks?
​​​you got a spare set of pins just in case? or are you going ***** out and hanging low
If you've got a supplier near you i'd get a set of shoes as well if you haven't ever had the rear discs off - that way you have them if they're worn and need replacing, and can return them for your money back if not. Saves having to pull the discs twice and really you should do them at the same time....don't ask me how I know....
Old Jan 13, 2018 | 02:16 PM
atikovi's Avatar
1995 S280 5-speed
Only 66,000 miles so pins and shoes should be OK, if not I have half a dozen suppliers plus 3 Mercedes dealers within 20 minutes I could pick them up from.
Old Jan 13, 2018 | 02:35 PM
quincross's Avatar
2002 E320 CDI
Yeah you should get away with it - that said I had a 47k in the shop with sticking set not so long ago. Customer obviously hadn't realised and they were worn to the metal! UK though, different environmentally and things corrode fast....
Old Apr 17, 2018 | 01:59 PM
lkchris's Avatar
'10 CL550, '12 GL550
Just messin wit you. I was all excited about finding a guide for doing W221 brakes when I saw this post. But imagine my let down after going to the link and seeing nothing about the electric parking brake. I mean, there are plenty of guides and videos for doing front brakes but none for our rears.
Your dash has a manual control for the parking brake ... push it and it's on, finger underneath to pull it and its off. You'll see the "brake" light on instrument cluster go on or off.
Do your rear brakes with key in accessory position and parking brake off. Listen to your radio.
Full disclosure: My CL is first Mercedes I've owned with Keyless Go. First thing I did is pull the start button off so I could use the key in the switch to start. That's how I find "accessory position." Maybe it's in the owners manual how to do it with the button installed.
