Upgrade the garage door opener module possible?
W221 S500
The stock opener operates 250-399mhz, my garage door is at 433 mhz (like the keyless module). How can i fix the module to work at higher mhz or i need to replace with a new one?
Car is S550 2007'
Car is S550 2007'
2006_W211_E 200 CDI
Hello,
You buy a new external modul feo garage door opener. Could be from any brand. This modul is a small recevier of remote control. And you connect receiver cables to directly plug of wall button cable (if you have on door opener).
This device will give you possibilty for can use other kind of remote controls and different frecansy.
This link you can see what kind of recevier i am talking about.
Nice remote kontrol
So, if you can buy such receiver which is also compatible operates frecansy to your car then connect to cable to plug of wall button cable and then you can control your garage door. And this adding will not change also your original own remotes.
I hope i could explain with my poor english language.
Good luck.
Nice remote kontrol
Good luck.
