2012 S550 4M O2 sensor change
Old Mar 30, 2018 | 07:55 AM
ClasseMiaMadra's Avatar
2016 S212
So Bank 1 Sensor 1 needs replacement. Any advice please? Do I need to take it in? Have it lifted? Or is it a driveway diy job? Any specific tools?
​​​​​​Also, after the change does the CEL go out or do I need to have it reset?
​​​​​​Thanks
Old Mar 30, 2018 | 02:58 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
I guess the most obvious question is how do you know which sensor to replace? Do you have access to SDS or similar to read out fault codes? If you have a CEL then you have thrown a code that will need to be cleared. I don't have any direct knowledge to share on replacing O2 sensors but am attaching WIS instructions for you to follow. Seems easy enough. (Are we sure that we are talking about O2 sensors?)
Good luck,
Bob
File Type: pdf
Old Mar 30, 2018 | 03:18 PM
2016 S212
Thanks Bob.
I believe so. Err code is P2626 and the description is O2 sensor 1 bank 1
thanks
Old Dec 11, 2023 | 01:44 PM
justchangeoil63's Avatar
2019 Mercedes S560
Hi there!
I'm getting the same code P2626, but the sensor 1 bank 1 is like In the middle of the firewall. Any tips on how to reach it?
2012 S550
Old Dec 22, 2023 | 11:05 PM
2019 Mercedes S560
Thumbs up
Ok, I finally got it done, and the P2626 code is gone after replacing my O2 sensor (Bank 1 Sensor 1 upstream in my case).
Below I attached a guide I made on how to change this sensor, it's simple on paper but working in tight spaces makes things very hard.
Good luck and let me know of any questions!!
File Type: pdf
