s class update disk
As of 2010, vehicles came with NTG3.5 version hardware which requires the unique activation code for each vehicle and update disk version and also require a different part number disk than used for 2007 - 2009 vehicles.
thanks
There was wide spread sharing of map updates for 2007 to 2009 vehicles drived by the cost of $250 per disk. They could have sold a lot more disks if they had a more reasonable cost, possibly $50. BMW charges $137 for two years updates which are issued twice per year.
The update will result in the system operating like a 2009 vehicle. If you are curious, download the 2009 owners manual from mbusa.com
Other changes with the update:
Real time traffic is displayed for most freeways on the map-- You can also view detailed descriptions for traffic slowdowns. It can take a few minutes for your vehicle to receive traffic data, be patient.
Estimated arrival time can be displayed on the lower right side of the map
When you approach an entry or exit from a freeway, you will usually see an enlarged picture of it on the right half of the display
At times you will see an indication along the bottom of the display showing which traffic lanes to be on as you approach an off ramp (as an example, if the two right two lanes both allow you to exit, if will show this)
Alternate Birds eye map can be displayed or you can see the original type map display
DVD movies can be watched -- but the display goes blank and only the sound remains once you start moving. In some installations you need to have the parking brake on to see the movie,
