'07 S550 - Climate Control Front Seats/ Cooling Seat Function
Old Oct 9, 2018 | 12:53 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Hopefully I will be able to explain my issue so it will make sense.
Recently, my Passenger Side Front Seat has developed a noise once the Climate Control/Cooling feature for the seat is turned on. Everything works and one can hear the fan blowing once switched on.
However, here my issue:
- When switching on the cooling mode, one can hear a noise like a "click", then goes away, sometimes sooner than other times, but the noise never keeps on going for a long period of time. When going down to the next lower setting #2, no noise. When switching from #2 to #1 (One blue LED illuminated), SOMETIMES a clicking noise. When moving from #1 to OFF, almost every time the clicking sound.
Has anyone else experienced this? Is maybe the fan blade rubbing inside at times, but not always? Is there a relay which could possibly be on its way out? WHAT'S THE FIX?
As mentioned, the cooling feature does work, I can hear the fan run, but this noise drives me crazy due to my OCD.
Any input is greatly appreciated, thanks very much in advance.
Old Oct 16, 2018 | 03:33 PM
konigstiger's Avatar
'71 Pinto
File Type: pdf
Old Oct 16, 2018 | 03:43 PM
S70Houston's Avatar
THANKS VERY MUCH konigstiger.
Yes, it is indeed a grinding noise, I will have to try to explain better in the future.
