driver control panel
Old Oct 16, 2018 | 07:29 AM
ramslot's Avatar
s550
the driver control panel stopped working shortly after changing the battery in the hood, in my s550 ,2007 model
Old Oct 16, 2018 | 10:46 AM
SilberGrau57's Avatar
2004 W240 Maybach 57
If you have a battery in the trunk (two batteries) then its likely you needed to remove the negative terminal from the trunk battery first before removing the under hood connections. This procedure was detailed in my owner's manual for my two-battery setup.
Old Oct 17, 2018 | 08:30 AM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
I have changed the battery in the engine compartment without removing any trunk battery terminals and I don’t have any problem, did it for both CL and SL.
