W221 air con condenser removal and replacement
Does anybody have experience of, or the repair manual instructions/illustrations regarding carrying out this procedure on an 2007 -S Class-W221_s320cdi- 235HP-VIN WDD2211222A157100?
How difficult? How much time? Any information appreciated. Thank you in anticipation.
'15 S550, '10 E350 P1/P2, '02 ML320
Yes, correct. The condenser is in front of the radiator, the evaporator is under the dash.
As for time to complete (not sure what the cost would be) I would guess most of a day. When I replaced my S550's water pump, hoses, radiator, thermostat, idler pulleys and belt earlier this year as preventative maintenance it took me 4 hours.
You would need to remove;
- the cooling fan
- the coolant
- the radiator hoses
- the radiator
Also will need to evacuate the A/C system if it is still holding pressure (perhaps not and the reason why you're replacing the condenser?)
Need to replace;
- the receiver drier
- the condenser
Add oil for that which is lost due to the condenser and receiver/drier replacement - sorry I don't have the exact amount, but you'll need PAG46 A/C oil
Reinstall all that stuff above that had to come out to get to the condenser
Evacuate the system with a vacuum pump and verify no leaks (e.g. system holds -25psi for 30-60m)
Recharge A/C with r134a
This is all from memory but should qualify for the 'any help is welcome' category.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Also if the car has never had the radiator replaced, you might consider it due to its age. These plastic-ended radiators have a nasty habit of leaving you stranded if you ignore them.
- the cooling fan
- the coolant
- the radiator
Need to replace;
- the condenser
