Dash board clock reset
i had my right wing mirror not folding .. I disconnected the negative battery terminal and reconnected it again .. the mirror worked perfectly fine but the dash board clock gone 3 hours back .. I tried to reset through the comand from vechile - system - time and date but every time I change the time the dash clock doesn’t move or reset .. any advice?
Let me venture a guess: If you try to adjust the date, It won't let you do that either and goes back to March or April of 2003?
It looks like it's happened in many cars, here's more info:
https://mbworld.org/forums/s-class-w...-problems.html
and if you can read German, here's more:
https://www.motor-talk.de/forum/datu...78.html?page=7
I found a workaround on the German Forum:for not being able to set the clock:
When you get into the car first thing in the morning, you have a short time window (maybe 1 min) where you can actually adjust the clock via Command
So wait until the car had a "good night's sleep" and give it a try.
if the car can't see any satellites (like an underground carpark) it may allow manual adjustment of the time and date (but will usually auto correct back to wrong on a drive)
if it see's a satellite that is beaming info it understands, it can temporarily show the right time and date (but will auto correct wrong with 90% of the satellites beaming info it can no longer correctly interpret post April 2019 as they wiz overhead)
a tips doc from Jan 2020 shows the polar bear software fix is now official
