Looking for STAR
Old Feb 5, 2019 | 07:10 PM
ivanof900's Avatar
2007 s550v, 2008 e63, 2006 e55
Looking for STAR
Does anybody know where I could buy a c3 sds I’ve been looking around but I’m new to those only discovered them a few weeks ago
thanks in advance
Old Feb 5, 2019 | 11:38 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
C3?? That's the old old multiplexer. Doesn't even work with newer software. What are your needs? Are you a shop? Personal use? Now a days even the C4 multiplexers are all crap. What vehicle years are you working on?
Old Feb 6, 2019 | 12:07 AM
ivanof900's Avatar
well I’m trying to use it for personal use from about 2006 and up
Old Feb 6, 2019 | 08:56 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Interested as well. 2007 S550 here...personal use.
Old Feb 6, 2019 | 09:00 AM
bha's Avatar
bha
13 GL350, 14 SL550
I bought a C4 from China and it has been great. Tried messing with personal installs of Xentry/DAS, downloading VMWare images, etc... then gave up and bought an entire hard drive from China with latest versions of everything installed.. Xentry/DAS/StarFinder/Vediamo/etc. The HD was under $100 and you have a choice of upgrading to an SSD instead of regular drive too which is much faster.
Look at Aliexpress and get a C4 and a hard drive.. has been working great for a year on 3 different MB's. Before that I had a C3 for 6 years which worked great too, but the wireless makes it SO much easier. Sit the laptop on the hood of the car instead of having lots of cables and wires going everywhere like I did with the C3
Old Feb 6, 2019 | 09:34 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
If you're working with newer versions of Xentry and Vediamo 5, you will need a C4 or greater MUX. I'm using a C3(called a compact C4 by vendors but doesn't have wireless) I purchased almost 5 years ago which works for my purposes. If I got a newer, 2015 or above model, I would spring for the C4 or C5 but I can do everything I need for my 2007 using the C3. A C3 system is going to cost you a lot less. I using Star/Xentry from 2014 and Vediamo 4.
Old Feb 6, 2019 | 10:00 AM
Anyone had issues with systems or HDs from China coming in with viruses?
Old Feb 6, 2019 | 10:13 AM
bha's Avatar
bha
13 GL350, 14 SL550
EasyPhil makes a good point. My C3 worked perfectly fine for a 2003 SL (R230), 2007 GL (W164) and 2007 S550 (W221). I haven't tried it on my 2014 SL. The C4 works great on those cars, it's just wireless.
If the C3 is a lot cheaper get that. If not, spring for the C4 because it makes life easier. Both work just fine.
As mentioned, if you have a 2015 or newer (or plan to get one soon) then you need a newer unit like C4/C5
Old Feb 6, 2019 | 10:46 AM
ivanof900's Avatar
Could you link me to one I have a pretty fast dell that I could put a hd on so if possible I’d like to get one I’d be working on my 07 w221 the most maybe my w204
whats the difference between both of them I’ve seen people do more with xentry but haven’t really seen vediamo much I’d probably be doing a lot of repairs and stuff for friends or personally so I’d like to have the step by step instructions that xentry had
Old Feb 6, 2019 | 11:19 AM
bha's Avatar
bha
13 GL350, 14 SL550
https://www.aliexpress.com/item/2015...537557558.html
Here is the one I bought. Available in 320/360/500GB hard drives, or an SSD. I bought the SSD even though more expensive, it runs really fast.
I have personally never used Vediamo.. not sure what it does. But I have Star/Xentry from 2018 (I believe they update it regularly.. the link above is for Dec 2018) and it works great for everything I need.
I have used mine on an 07 W221 S550 and have also run it on a friend's 09 W204 C350 so it will work on your cars for sure
Old Feb 6, 2019 | 12:40 PM
ivanof900's Avatar
what have you used it for specifically on your 07? And did you need. To buy a license for xentry?
Old Feb 6, 2019 | 01:14 PM
bha's Avatar
bha
13 GL350, 14 SL550
never opened Xentry so no idea if a license was required. I use DAS for everything. On my 2014 I will need to look into Xentry but for a 2007 you don’t need it
i usually run a Quick Test that tells you every error code in the car. You can further diagnose or reset errors too.
Have also used used functions for:
upgrade software in modules. For example when the windows stop opening and a software update is required.
Release pressure from a strut before replacement
set proper ride height or adjust it (lower the car etc)
and lots of other stuff
if you work on your car, you need this!
Old Feb 6, 2019 | 02:14 PM
T.H.Carrera's Avatar
2012 w221
can this be put into any windows laptop by simply swapping the hdd ?
Old Feb 6, 2019 | 02:17 PM
EasyPhil's Avatar
Vediamo allows you to do things like code a set of headlights without having to have an account with mercedes. It also allows you to activate and change many things you cannot do with Xentry/DAS like remove the speed restriction for editing addresses and such for navigation.
Old Feb 6, 2019 | 02:19 PM
EasyPhil's Avatar
For me this is a non issue because the machine I have it on never connects to the internet.
Old Feb 6, 2019 | 02:21 PM
2012 w221
another question, are you able to update all your car modules to the latest versions (lets say tranmission, command) etc with simply connecting it to internet and it grabbing the required files and then flashing offline?
Old Feb 6, 2019 | 02:22 PM
EasyPhil's Avatar
It depends on what machine the hard drive came from, usually it's a Dell or a Thinkpad. If the OS on the drive is Windows XP, you're restricted to what type of machine you can put it in, meaning Dell laptop for Dell hardrive, Thinkpad for Thinkpad hard drive.
Old Feb 6, 2019 | 02:26 PM
EasyPhil's Avatar
You can update your car modules but you have to configure your system to do offline coding and also acquire the firmware updates for the modules, ******* is a good place to find all of that stuff. I've updated Command, Audio, door modules, Keyless Go, radar sensors, telaid to mbrace, plus some other stuff.
Old Feb 6, 2019 | 02:32 PM
EasyPhil's Avatar
Vediamo allows you to variant code without having an online Mercedes account. I replaced a set of headlights, they worked fine but the active curve function wasn't working and I would get an error indicating such every time I turned the car on. The dealer wanted $169 to code the lights and I wound up doing it myself with Vediamo and it took 15 minutes. You can also flash modules with Vediamo if you have the CFF files. I've haven't used Vediamo to flash any modules as I'm just getting used to using it. I have used it to remove the restrictions for enterning intormation while the car is in motion. I plan on adding two additonal radar modules to my rear bumper so that I can enable the Parking Guidance feature and do a Blind Spot Assist retrofit at a future date. I'll use Vediamo to enable those features once I have all of the hardware in place.
Old Feb 6, 2019 | 03:16 PM
MBENZTECH's Avatar
If all you need is to read codes/clear codes/actuations and so on....... you can use Xentry Passthru. It is used with J2534 devices (passthru). I have used many passthru devices to include the Tactrix Openport 2.0. It's $169 directly from the company and it works good with Xentry Passthru. Xentry Passthru is good for 2006 and up vehicles. It will not work with older ones. I have even programmed online with it. If you are needing it to code modules and make system changes then you will need Vediamo, Monaco and so on.
Old Feb 6, 2019 | 04:41 PM
ivanof900's Avatar
so what all would I need just the hard drive or do I also need the wires, multiplexer, and etc..., I’m trying to do as much as possible with both cars and maybe even help a few others in my area so they don’t have to go to the dealer and spend money for something that can be done in minutes
Old Feb 6, 2019 | 05:02 PM
bha's Avatar
bha
13 GL350, 14 SL550
You need a laptop, hard drive with software, and a multiplexer (c3 with cables or c4 without)
Old Feb 6, 2019 | 06:31 PM
ivanof900's Avatar
ok well I’d like a c4 since that seems to be the best way to go, I would need a multiplexer regardless, you linked me to the hard drive could you by any chance link me to the rest ? Thanks a lot for your help so far btw
Old May 5, 2020 | 06:13 PM
shih1919's Avatar
w204 c300
Are you saying that Tactrix openport 2.0 is also compatible with Vediamo ? Is it Vediamo 5.0.1 version?
Old May 6, 2020 | 09:02 PM
EasyPhil's Avatar
I've used the Tactrix with Vediamo 4 and it should work with 5.0.1. (Edit: Tactrix doesn't work with Vediamo 5)
