2008 S550 Clock Reset
Old Mar 14, 2019 | 08:30 PM
Polo35m's Avatar
2008 S550
Hey guys I've got the dreaded an Infamous S550 clock reset problem going on. I can go into the command and reset the clock as well as choose summer daylight savings as well as choose the correct time zone and the digital image display of the clock shows the new correct time but the actual analog clock on the console will not reset. I've Googled and searched ad nauseam and read that sometimes it takes a day or so to reacquire satellites blah blah blah But it's been 4 days now and it still won't reset. Anty suggestions would be very helpful. Again this is a 2008 S550. Thanks in advance. Ps.... everything in this car and I mean everything functions flawlessly meaning there are no blown fuses or any other irregularities going on.
Old Mar 15, 2019 | 12:22 PM
mitanworb's Avatar
2007 MB S550 4Matic
I have the same problem so I will be interested to see if anyone knows a fix. I did read somewhere in here that the clock could just be bad..
Old Mar 15, 2019 | 01:36 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
It's not that it won't reacquire the satellites, it's that once it does there's a problem with how the satellite data is interpreted, which resets the time to something useless.
So the trick is to reset the clock before it has a chance to sync. You can do this by letting the car rest overnight and then first thing in the morning put the car into key position 1 (one press of the start/stop button with your foot off the brake). Once in position one, you can go in and change the time and the analog clock will adjust. I just did this two weeks ago after I changed my starter, works like a charm. Apparently there's no fix for the date, and honestly I really don't care that much, as long as the clock is right.
Old Mar 15, 2019 | 02:08 PM
Polo35m's Avatar
2008 S550
Awesome. I will try that trick tomorrow morning. I to do not care about the date beimg incorrect just the time. That was my first thought that maybe the clock is just broken but it actually keeps perfect time to the minute it's just the hour is off. It has never lost time or never lagged.. I did think of another idea maybe remove the fuse that corresponds with that clock and wait for the correct time to roll around and then reinstall the fuse!
Old Mar 16, 2019 | 01:09 PM
mitanworb's Avatar
2007 MB S550 4Matic
Just went out and did it, worked like a charm, thanks.
Old Mar 17, 2019 | 11:54 AM
Bklyn's Avatar
S550
I had the same problem. It took me 2 days to make it happen. I wish I can tell you what I did but I did so many things until something worked. What I can tell you was that I was in Park in my driveway and that is when it worked. Is it possible that it only works when the car is not moving and in Park? I do love to see the clock spin around like that. It is great fun.
Old Mar 17, 2019 | 04:56 PM
Magnus Rostadmo's Avatar
S550-07 Obsidianschwartz A200Turbo-07 Kosmosschwartz C200T -10 Tenoritgrau
Owners manual is an underrated book. It clearly states ....
To adjust time & date make sure the GPS is OFF. Switch off before stopping the engine. Key out,
Key in - turn to pos 1 - (GPS will not start in this pos) .... Adjust time/date/timezone and remove key again. Next time you fire up all is ok --- works for me every time.
Old Mar 17, 2019 | 09:18 PM
Polo35m's Avatar
2008 S550
Thanks to all those that responded and yes the ticket is key in position 1....IE press start button once, foot off brake, then go in the command man menu... works every time.
Old Mar 18, 2019 | 11:27 AM
Bklyn's Avatar
S550
Please oh LORD, let me remember this in the fall!
Old Mar 18, 2019 | 04:35 PM
kn51's Avatar
2007 S600
This has to be the oddest bug with the car I've run across. Used to be able change it whenever (funny thing is the stupid clock rotating on the dash mightily impressed them). Stopped working, was an hour behind and no matter what I did couldn't fix it. Until I ran out, did the key on routine and quickly change the time and then it worked. Who knows.
Old Mar 18, 2019 | 04:58 PM
dlafever's Avatar
Well honestly my 2001 E430 ALWAYS had the correct time. After reconnecting the battery it was <5 mins and the correct time would appear on the instrument cluster. So for this to be a thing, no less a documented (owner's manual) thing, is really just dumb.
Old Mar 19, 2019 | 12:15 AM
Bklyn's Avatar
S550
Nice. Complicated, but nice.
Old Sep 23, 2019 | 09:57 PM
Mike Pierce's Avatar
2008 s550
2007 - 2011 S550 CLOCK RESET
Guys, here the easiest way to reset the time on 2007-2011 S550, open the fuse box (drivers side under the hood) 4 allen screws. Remove fuse's 39 and 25 at 11:55pm, replace them at 12:00 am....See if the clock has reset to 12:00 am, if so your done. If not, press the ignition button to position one and the clock will automatically go to 12:00 am. This doesn't fix the date, but who cares....
Old Jan 2, 2020 | 01:06 PM
MontereyPop's Avatar
S550
I also have a 2007 S550. After 12 years of being able to routinely and easily change my dashboard analog clock to DST and back, it all of sudden stopped working. Although the time was correct on my COMMAND Screen, the analog clock in my dashboard would never adjust to the correct time.
So, I went to my local dealership, requesting a fix, they told me that the dashboard clock was defective and I couldn't buy a replacement. This forum saved me from wanting to sell my car. I searched this forum to see what other S550 owners were doing to fix this issue, and came across this solution and it worked like a charm. Thank you MB World Forum, Thank you.
Old Jan 2, 2020 | 01:14 PM
BOTUS's Avatar
S500
read the other clock fix post by Polar Bear make yourself an update CD and do the real fix he released
Old Apr 23, 2022 | 10:58 AM
wideglides's Avatar
W221 S500, C43 AMG Cab
Thanks everyone. My clock been unsynched for years. The position 1 tip just worked for me. MB wanted £400 to fix it. Thanks.
Old Apr 23, 2022 | 02:16 PM
BOTUS's Avatar
S500
stop pretending and install the software update it needs - there is NO other fix - u can do it at home in 10 mins
https://mbworld.org/forums/s-class-w...ml#post8494456
Old Apr 23, 2022 | 03:54 PM
wideglides's Avatar
Great. Thanks. Sure you are right. Bit new to all this and nervous of making a mistake! Need to ensure I have correct kit to burn the disk in the format required and then load it correctly. I have had my car for nearly all of its life and it is beautiful. Everything works and all immaculate. Don’t get the chance to use it much, but don’t want to part. Will check it out to see if I feel confident to upgrade the software. As you say, that is the best way to proceed. In the meantime, the clock is showing the correct time! Thanks again.
Old Apr 24, 2022 | 12:24 PM
BOTUS's Avatar
S500
you shouldn't go wrong - if you make a good disc it will load - if its wrong the car will not bother to do anything and will tell you - they aren't completely stupid at the factor (just mostly)
Old Apr 24, 2022 | 04:12 PM
wideglides's Avatar
Got it. Thanks. 2006;S500. UK. 5.5l. 388hp
Separate item. Anyone had squeaky front suspension noise when cold which wears off? Stops if you raise air suspension even if cold.
thanks. Best.
